h22pwrdcivic
I need to clean out my garage, help me out!!!!
September 20th my wife will be having our first son....i need to get things out of the way so that i can start making room for his stuff.
Well it has come down to 7 days before the lil mans birth and we are in need of money. I hate to do it but i must start selling of my engine parts. prices on h22 engine parts are firm, but negotiations are always welcome.
H22 Cylinder head with stock cams and STR cam gears. head has been magnafluxed and straight edged and pressure tested...all came out perfect. the head has had a port n polish job done and the combustion chambers smoothed for optimal performance and fuel atomization. This is a 2000 model head and when purchased only had 47 miles on it, the head since has never been used. all head components have 47 miles on them as well. will include a oem head gasket and intake and exhaust gasket with the set. will also include a black valve cover. $keeping it
1996-2000 ek coupe stock springs $40
1992-1995 civic coupe wiper motor transmission and both arms all in good shape not stripped out. $40
JDM H22A Closed deck block. 1 cylinder needs to be sleeved due to a nick in the wall. comes with main girdle and main bolts as seen in pic #3 $200
50mm H22a crank **has been turned .25** $100
ill call these trial and error bearings. never been used, only opened to plastiguage crank in block. these are oem h22a 50mm honda bearings i have 5 browns, 3 blacks, and 2 greens. paid over $100 will take $75 for all
Also have 6 pink and 2 yellow 55mm main h22 bearings.
they ordered the wrong ones and because they are special order i cannot return them. 4 pink and 2 yellows are unopened. 8per half
pics later.
MB Quart QM 130 5.25" crossover and midrange $50
Goodridge steel braided brake lines for 1992-1995 coupe with rear drums, for rear only. $20
Prestige Car alarm with only one remote.
Model # Aps 786 not sure what all features it has b/c i pulled it from a used car when i worked for a stealership. Car Audio & Mobile Electronics - Speed & Sound Electronics Corp. says it has remote start and keyless entry. $50
Passenger and drivers side airbag and control module and all wiring between fuse panel and all 3 pieces will throw in fuse panel as well(with fuses, ha) steering wheel not included $200
not my actual picture...borrowed from carparts on ebay but i have this exact spoiler except it is a wings west 3 piece spoiler.
here is a picture of the wing installed on my car. $100
Centerforce Pressure plate and dual friction sprung disc for H22
(i painted it black b/c i cannot stand orange, got bored while it was sitting on my shelf, then i decided to h2b this project) pp has been resurfaced all for $100
TCS H22 dual friction sprung disc...brand new never used only pulled out of the box for picture. $65(call tcs that is exactly what i paid for it)
B16 jackshaft, with a female end..$75
b16 drivers side axle, damn near new, has male end for jackshaft. $50
h22 starter....$20
17" tires, decent shape, bead of two of them is ripped up(not sure if it would hold air) i have 4 tires 205/40/17, 2 are sumitumo(have 7/32's tread) 2 are wanli(3/32's tread) email for more pictures...make offer
IBM ThinkPad does not power up, might be the chargers i have... perfect for datalogging or dyno tuning programs. not sure what is installed on it. make offer
H22 pistons and rods, pistons are no good/rods are, only 3 shown 1 is at my work. make offer
H22 .25 oversized piston rings 3 complete sets unopened 1 set is missing one oil control ring. paid 130 for all four.....yours for $75
1 set of std 50mm ACL Main Bearings opened just for plastiguaging $30
1 set of Clevite 50mm main bearings .25os opened just for plastiguaging $50
1 set of clevite 50mm main bearings .50os opened just for plastiguaging $50
THINGS I NEED:
B series jackshaft and drivers side axle.
(axle must be female, making the jackshaft a male)
EG air bag delete tray for pass side. black in color
decent set of rims, any size, so long as they fit on a civic.
all prices are listed as picked up and are always the price or best offer received. all items are located in Smyrna, Tn.
all items listed here are my property, owned by me(airbag rules, can provide vin of vehicle if needed), selling all parts in an as is condition, no refunds after sale is complete.
Please PM me if interested in any of these items as i tend to not follow the board that closely.
pics later.
h22 starter....$20
THINGS I NEED:
