jkgultimate
Hello, how is everyone doing?
I am selling of 4 harnesses. Three of them are the "A" type and one of them is the "B" type. This is probably the best harness on the market right now because of the one piece design. Below is the description:
[/FONT]
[FONT="]Every other harness on the market uses a large plug made to solder to a circuit board. The problem is we aren't using a circuit board. And to make it work the pins must be cut and have wires soldered to them. Those wires often break off or disconnect quite easily. Our custom molded end fits all the OBD 2 plugs and has push-to-seat, or insert pins, just like the factory plugs do. No chance of a wire breaking loose!
All wires are machine cut and connected with a tool designed for the job, not a cheap pair of crimpers. After assembly each harness is computer tested for a solid connection, ensuring that all wires are in the correct locations. This is the best conversion harness currently available on the market.[/FONT]
We have TWO versions. Please check Below for your application.
Application:
OBD2A
Any 1996 + Honda or Acura to plug-in any OBD1 Computer ( ECU )
OBD2A to OBD1 Harness
1996 to 1999 Acura Integra
1996 to 1998 Honda Civic
1996 to 2001 Honda Prelude
1996 to 1997 Honda Accord
Application:
OBD2B
Any 1998 + Honda or Acura to plug-in any OBD1 Computer ( ECU )
OBD2B to OBD1 Harness
2000 to 2001 Acura Integra
1999 to 2000 Honda Civic
1998 to 2002 Honda Accord
- [FONT="]Custom molded large OBD2 plug end [/FONT]
- [FONT="][/FONT][FONT="]Developed like an OEM plug, not a circuit board plug [/FONT]
- [FONT="][/FONT][FONT="]Machine assembly, eliminating factory defects [/FONT]
- [FONT="][/FONT][FONT="]Every harness is tested before it leaves our warehouse by a qualified technician [/FONT]
- [FONT="] [/FONT][FONT="]Our units are manufactured in Japan to insure top quality (We do not cheap out on our part)[/FONT]
- [FONT="]A must for performance chips and tuning
[/FONT] - [FONT="][/FONT][FONT="]Lifetime Warranty [/FONT]
[/FONT]
Application:
OBD2A
Application:
OBD2B
