jpoenitsch
I have a d16a6 out of a 90 SI CRX. Need a fuel rail, mine is missing. Found one off a 89 DOHC B16 and as far as I can remember think they are the same, since the intake manifolds are made with in the same style.
Compared a picture of a SOHC fuel rail from a 91 CRX SI to the picture of the 89 DOHC fuel rail, size for size, and mounting holes look exactly the same , as well as injector hole spacing. I can't tell these two apart!!!!!
I just want to double check and see if anyone had any problems doing this with injectors sealing or mounting or anything.
Any info on differences would be appreeciated.
Thanks!
Thanks!
If I could I would send you the pictures of the DOHC rail and SOHC rail so you can see what I am talking about. The mounting holes look the same, and I wouldn't think the injectors wouldn't be any farther apart on the SOHC TO DOHC series.
