fuse
  • Thread starter Thread starter formby
  • Views Views 860
formby
learning in progress
its number 8 on my 91 crx dx fuse box...cluster/runing light fuse....it keeps blowing and i dont know why......what can i do? what could it be>? HELP
look around for loose wires.bad grounds... pull the cluster, make sure everything is pluged in correctly... etc
okay i will...is it bad to get a bigger fuse/ or smaller? incase i cant find the problem...
yes. its popping for a reason. find out why.
if you don't, you'll most likely going to fry something
damn man....
i know this might be a stupid question....were do i start? i have no idea
the reason i ask is because the damn bitch that had my car, fucked all of the wiring under the dash up...i had to pay $50 to best buy to put a new radio harness on the car...but everything works exept that damn fuse
i have a push button start and the shift light is hooked up to that power
source so i think that might be the problem.... and the cig lighter wires are just laying in there....
