gsr block b16 head. obd 1 or 2 and which ecu?
  • Thread starter Thread starter boosteda4
  • Replies Replies 1
boosteda4
doing a swap in my buddy's 98 lx. i have a 00 pr3 head with type r springs. it came off a b16a2. also got a gsr tranny, type r linkage, axles, all the mounts, brackets, b16 intake manifold and tb, bpi intake, headers, msd, and a full rebuild kit w/ arp hardware. lookin for a gsr block right now.
my question is what ecu and harness should i be running and which obd? The car is a obd2 non vtec, i believe that head is obd2. so which ecu and distributor should i get?
also i have pr3 pistons lying around. whats the compression ratio if i use those pistons or if i use gsr pistons? thanks for any and all help
since ur tryin for a poor mans type r i think i would go with a p28 ecu. and a vtec wiring harness. ur car takes an obd2 harness if u run into problems just get an obd2 to obd1 conversion.
