h22 eg tranny problems
  • Thread starter Thread starter blankslat5
  • Replies Replies 1
blankslat5
i have an eg and put an h22 swap in it. everything works really good motor runs good and tranny is good except for 5th gear. it just wont go in. it doesnt grind or anthing it just wont go into gear. i was told that because of the angle the motor is in oil in the tranny and motor is off a little. and that made me think that when oil is low in the tranny 5th gear is the first to go because it sits up the highest. just seeing if anyone has had linkage issuses. any input would be helpful.
try going over your cables and make sure they arent binding when you try to shift into 5th you may have to adjust the cables a bit or move them also are you sure it worked before you swapped it?
