HELP! clutch and flywheel issues
  • Thread starter Thread starter evilgsr
  • Views Views 917
evilgsr
just had a fidanza flywheel installed on the gsr and after driving it i really couldnt tell much of a difference between it and the stock one i assumed that with a lightened flywheel you would feel a dramatic difference in the way the car reved and i was told i wouldnt be able to drive it easily and it feels exactly the same as the stock one.... i also had a centerforce clutch installed and its making a scraping/spinning sound when i give it throttle i was told its the throwout bearing seating itself ugh i dont know what to think if someone could set me straight itd be much appreciated
i have a clutch master 8.5 lb flywheel on my car and it revs fast as heck (act clutch). when i shift real fast the rpm goes up .4 of an rpm thingy, and then, it goes down. how heavy is your light weight? when i tap the gas my rpms shoot up way faster than my stock and it drops way faster (which is supposed to happen) see if yours does the same.
:withstupid: yea you can def. feel a differnce...
drivetrain is nothing you should guess at...go take it somewhere
well after driving it all day the noise went away and i can tell a difference with the flywheel (especially after 4500 rpms) so i suppose everything is ok keep my fingers crossed that the stock throw out bearing holds it didnt show any signs of damage however
