Help on Fuel Management on SOHC motor
  • Thread starter Thread starter gettocrx
  • Replies Replies 3
  • Views Views 775
gettocrx
Hey again! I'm planning to go with bigger injectors on my SOHC CRX DX with si head thats boosting 5 psi with a garret t3. I have a MSD high flow fuel pump with a 8:1 FMU. I was told that the 1st gen DSM 450cc stock injectors will work. What will I need, in order to run these injectors?? I also want to boost a little higher. What would be safe?? (thinking of 7psi)
Thanks again for all your help! :D
you got some facts mixed up.
if you are using an FMU, you use stock injectors. at most, 310's.
dsm 450s will flood.
if you want to go a little higher in the boost, throw out the fmu and missing link, and pick up an AFC controller, and run the "hack".
No. This is what you need: AFC, 450cc injectors, high flow (not high pressure) fuel pump- either in tank or in line, and maybe a 1:1 FMU just to be safe. If that's too much fuel, you can always trim it back using the AFC.
