Help with wiring?
hey I need sombody to tell me what I need to do for wiring for my H22a in my 90 accord I'm not sure what wiring I do I heard there's only 4 wires to move but I'm not sure. If someone could help me out that would be the shiznit! thanks :worthy:
It's not that you have to MOVE wires. You have to ADD and LENGTHEN wires.
2 wires for VTEC
1 wire for IAB
1 wire for knock sensor
Miscellaneous lengthening of wires that I can't remember off the top of my head, but are VERY apparent once you start the swap and try to plug some sensors in and find that the plugs are too short. :)
Once h22a.org goes back online, they've got some pretty detailed instructions.
Thanks for the response. I know I have to move wires though I have a friend with a 91 accord with a H22a (thats where I got the motor from he thought it was blown got it for $200)he used the h22 harness and had to move wires so I think I'll just go off his wiring thanks for the response dohc vtec. :worthy:
Well, that's why. It'll be much easier if you just use your stock Accord harness and add some wires. Anyway, that's why I said you have to add wires, not move them. You'll definitely have to mvoe wires if you use the Prelude harness.
