help??
  • Thread starter Thread starter tucrxbo
  • Replies Replies 6
  • Views Views 751
tucrxbo
i have a turbo gsr
problem is my vtec is gone and its cutting out at 6500
if anyone has any help for me it would be greatly appericiated :worthy:
huh?
if you're throwing a code, of course the car isn't going to run good.
PULL the code. there's a how-to int he articles section
problem solved
it was the vtec pressure switch
didnt have the monoey to get a new one yet
but if any one is in my situation you can hit it against the ground really hard And it should work again for a while
Mine lasted for another day or two then I took it off again smacked it against the ground and its been about two days and still works fine
:tfg:
Wow... I'm still laughing about that. I think you should pin that in the How-to section.
If the VTEC Pressure solenoid does not function in your B18, pull it off your car and beat it on the ground.
