high compression gsr help???
  • Thread starter Thread starter stewyrx786
  • Replies Replies 1
  • Views Views 2K
stewyrx786
99 gsr block
cp b16 high comp 12.4:1 pistons
99 gsr rods new
standard headgasket
arp head studs
what cams and other upgrades should i make???
Call up cam manufacturers and see what they recommend for that compression and the RPM range you're looking at. 12.4:1 can support some pretty aggressive cams on street tunes. Upgrade your valvetrain if you get big cams. Port your head if it's off the block.
Make sure the 12.4:1 is in the GSR block and not the B16- there's a difference. That will affect what parts you choose to finish the head.
Welcome to HondaSwap!
