300hph22civic
This is a F22B1 2.2 L SOHC VTEC engine out of a 94 accord Ex, this motor is rated at 145hp, great upgrade for your non-vtec accords.
F22B1
Displacement (cc): 2156
Power (bhp@rpm): 145@5500
Torque (ft/lbs@rpm): 147@4500
Compression Ratio: 8.8:1
Bore (mm): 85
Stroke (mm): 95
Cam Design: sohc
VTEC?: yes
OBD: 1 or 2
Year(s) Produced: 1994-1997
In the following car(s): Honda Accord EX
I will take $1200 for everything, what is included?? You get the engine, 5spd. transmission, ecu, and wiring harness, (axles if you need them, as well as shift linkage, and shifter) that would be thrown it here are some pics , and if you are interested please feel free to email me at vidomi@msn.com or call 864.202.3709
F22B1
Bore (mm): 85
Stroke (mm): 95
Cam Design: sohc
VTEC?: yes
OBD: 1 or 2
