How much hp??
Status
Not open for further replies.
mozzandherb
I know this is a very generalized question to ask, but how much hp at the crank can I expect with this setup?
92 Accord weight 3000lbs
jdm h22a
exedy stage 2 clutch and flywheel
over bored throttle body
throttle rotor
aem cam gears
aem fuel rail/fuel pressure regulator
hondata s100 chip
zex 75 dry shot
4-2-1 headers 2.5 outlet
2.5 inlet/outlet cat converter
aem short ram intake
cat back exhaust
I think that's it. Any guesses?? Thanks
Thats what a machine called a dyno is used for. you can expect all the HP in the world. doesnt mean your going to get it
jdm h22a
throttle rotor
aem cam gears
hondata s100 chip
zex 75 dry shot
cat back exhaust
[post=534343]Quoted post[/post]​
A GUESS:
Most of those arent power adders.. Not by themselves. Like cam gears. They can only hurt your power unless you dial em in on a dyno.
Overbored TB: 2 HP. maybe, probably not though.
cam gears: 0, unless tuned properly.
Fuel rail/press reg: 0
hondata chip? Has to be tuned to your car to do any good.
headers: 7-8 hp?
intake: 4-6 hp
converter/exhaust: 7 hp
Zex 75 shot: 75 Hp.
THIS IS JUST A GUESS, put the flame throwers away.
1003937786874867637622 hp to the crank for sure. Another one of these huh?
maybe if you are lucky 200 to the crank but I doubt it.
[post=534447]Quoted post[/post]​
Thanks for the guess, I hope your right! B)
Originally posted by mozzandherb+Aug 2 2005, 03:37 PM-->
integraslut78
[post=534767]Quoted post[/post]​
Oh I didn't see the Zex kit in there the first time I read this so I would like to change my original answer from 200 to 250 to the crank :)
Status
