How to bore out a b16a2 intake
  • Thread starter Thread starter Meeko0-o
  • Replies Replies 3
Meeko0-o
will a dremel cut off wheel work good. Because those sand wheels shread easliy or will a engine machine shop do it ? 70mm tb on a b16intake stock manii. If anyone has done this please show pics and what u used
What exactly are you trying to do? Are you trying to just do a port matching?
I've done it on my mitsus. Port matched a big TB to the plenum inlet, draw the ID using a sharpie then do the same for the other side at the runners.
Used a sanding drum for the TB side and metal cutting bits for the runner side
