i have a whole front end or a GSR
  • Thread starter Thread starter tip
  • Replies Replies 3
  • Views Views 777
tip
i have the entire front end of a GSR and i was wanting to know exactly what parts to take besides the swap itself..? Brakes....what all parts, Sway bar....what all needs to be taken off with this to work, and anything else all the way back to the cross memeber that holds the stering gear box. Thanks for all info.
the entire knuckle is what you want for the brakes
the sway bar and end links
and if you have it i think the GSR MIGHT have a closer ratio steering box if you want that too
Quoted post[/post]]
yeah i have it and it is still attached to the cross member itself......will the cross member bolt right up or would i have to take it all apart..?
