Installing notebook RAM
  • Thread starter Thread starter whitecivic
It really depends on the model of the notebook. some have a simple latch on the bottom where you can unscrew and pop it in (difficult part) and some have it under the keyboard.
Go to the manufactuer's site, itll probably have a diagram of the specific model.
Installing memory
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size.
Please consult a qualified technician or contact your local Acer dealer.
