its not letting me post pictures....
here are some pics of the turbo... i would appreciate if some one could post some specs on the turbo.
Compressor
serial plate
Internal wastegate
Compressor and turbine inlet side
What is this thing.. and how does it function?  Im pretty sure i need it, but how do i hook it up?
Im trying to post this up, and i keep getting an error message that says:
You are not allowed to use that image extension on this board. A valid format is: http://www.domain.com/picture.gif, an invalid format is: http://www.domain.com/picture.one.gif
First off, I took the spaces out between the tag and the URL, and I changed the [img] tags to all lower case... works now. :)
Secondly, that thing is a single stage boost controller. The two big nipples, you'd put in line with the wastegate signal line, and the smaller nipple, you'd run to upstream of the compressor inducer. The nut and screw are the adjustment, and the wires would go to a relay controlled by a switch. A friend with a 323 GTX had his solenoid hooked up to his AC button so when he pushed it, he got 12 PSI rather than 6.5 or so. :) It works good if you connect the hoses up properly. I had one in my Civic.
Your friend is my hero mang!!!
323 GTX wo0000ooo00o0t!!
1.6L with 180 hp/180 torque. :worthy: (US Spec, JDM has a 1.8 with 180hp/180tq)
Where the hell did you find that IHI VJ11??? That would PERFECTLY fit up to my old 1.8 with the Corksport GTX manifold! :angry: :( :angry: :(
Found it at the junkyard yo.... i could probably get another one...
Yo Loco, how much would a used RHB5 go for if it was in "ok" condition. As in very little movement in shaft, and no major mechanical problem?
if i get another one ill post up, and probably sell it..
