just did a compression check?
  • Thread starter Thread starter 92egcivicls
  • Replies Replies 7
  • Views Views 952
92egcivicls
just got done checking my compression on my b18b1 motor,wanted to check it before i made any real plans for the motor/car.
#1=185,#2=190,#3=180,#4=185...
pretty nice and even across the board,but i dont have a manual YET,to know what the limits are?
is this withinn tolerance?can someone post the high/low limits for the b18b1.
anythoughts,thanks steve
Close enough!
Perfect is something like +/- 5psi, so you're in good shape. Those numbers are about par for any factory b18a1/b1 I've checked.
Sounds good. I'd buy a b18b1 with that compression. That'd make a good DD.
Not bad, but it's not good either. Sounds like it's had a medium-hard life. It'll be fine as long as you don't go F/I with it.
Might be a good idea to rebuild it either way.
From a Haynes:
B18B1
Standard...............................................199psi
Minimum...............................................135psi
Maximum Variation between cylinders....28psi
thanks thats the info i needed to know!,now can someone tell me a decent header to go with my ls swapped eg civic?i have ac and would like to keep it.and be able to line up with my current exhaust.without breaking the bank:)
