Just need to clear things up about my swap!!!
  • Thread starter Thread starter leonc
  • Views Views 740
leonc
I have a 94 civic ex which as most of you know has a d16z6 (SOHC Vtec, OBD1).
I am going to order a SiR II complete motor swap(OBD 1)
Here is a list of what comes with it:
Engine
Transmission 5 Speed Hydrulic
ECU
Disterbutor
Alternatur
Starter
A/C Compresser
Power Steering Pump
Intake Manifold
Exhaust Manifold ( JASMA HEADER )
Down Pipe
Half Shaft
Axles
All Sensors
Clutch
Fly Wheel
Pressure Plate
Shift Linkage
Do i need a wiring harness? Mine is already wired for Vtec.
What else will i need to make this swap as easy as possible?
Thanks and God Bless
Leon
Re: Wiring harness: Nope...you have what you need. Im also assuming you have the stock P28 in there as well?
Things to make it go easier? A surplus of extra cash for broken sensors and miscellaneous broken parts. Trust me.
*Edit: Just read that you said your swap came with the ECU, meaning you now have a P30.
Use your harness (unless you can score a cheap 94-95 GSR, or DelSol vtec harness) should be one of the more straight forward swaps :)
