redef91
i recently did a compression check on my b18c5 and cyl. 1 tested 180 and 2,3,4 all tested 210psi. the reason why i tested for this to begin with was my car would smoke a bit when i would stop at a stop light and take off again. my question to uses would be is this bottom end issue or head issue? also when i dropped a teaspoon of oil in to cyl. 1 the compression rose to 205psi
