LS Turbo Oil Pump Question
  • Thread starter Thread starter jtornado
  • Replies Replies 3
  • Views Views 703
jtornado
I'm currently building my LS and im just wondering if a Civic JDM TypeR B16B OBD-1 oil pump will fit on my b18a and could this oil pump work just fine or would someone else recommend the Integra GSR/TypeR oil pump????????
I'm pretty sure all b series dohc vtec oil pumps are the same. GSR, B16, B18C are all good upgrades for your build.
Thanks a lot man. I just did some research last night after I posted this thread. The only thing that makes a the nonvtec oil pump lack oil pressure is because of a washer. Vtec oil pumps do not have the washers also you can put more tension on the spring for the plunger and chamfer the ports for smoother less sharp openings. Easy and cheap ways to increase oil pressure. Ill just probably buy a ctr one for $50 new.
Ya man. Ebay is my friend for that stuff.
