LS Turbo question
  • Thread starter Thread starter Triton83
  • Replies Replies 2
  • Views Views 861
Triton83
I have a stock B18b1 in my 94 civic. I just Installed my turbo and I ahve it set at 7lbs of boost. What Kind of tune do I need??
a very good one!
what kinds of tune's are you refering to?
u want some pachabell's cannon? that's a good tune, reused by most rock bands.
dont just through an arbitrary amount of boost at it. you need to go to tuning shop, and slowly increase the boost untill the calculations of effective compression in the cylinder is where you feel safe. you need a good experienced tuner.
what turbo are you running? different size turbos move more air (CFM or LBs/Min) than others. 7psi on one turbo may be 270 CFM, but 360 CFM on another.
I'm not sure what question is being asked here, but you really need some form of tuning before you drive. Get CROME, or Turboedit, those are two fairly cheap and decent programs to tune with. Your tuner should know these names.
