ls vtec questions
  • Thread starter Thread starter skellagher
  • Replies Replies 1
  • Views Views 748
skellagher
Elder Driver
ok so heres the deal i got a ls block that needs rings i am buying a 94-95 gsr rebuild kit. will the gsr ring and bearings work on ls block? need answer asap
Put P30 pistons in it and shot peen the rods (or better yet get aftermarket rods) OEM bearings (they are specific for each rod/crank combo and have engravings to express the color of the bearings to install) and ARP rod bolts/head studs. Get the rings for the P30 and make sure they are clocked correctly and have been ground/gaped correctly. It all bolts up to your LS rods. I would get the rebuild pistons (they're a little bigger) and have a machinist hone it out nice and true.
