jastunna1987
i jus bought my friends 93 civic EX, he put a d16y7 because he blew the d16z6 with some NOS. Right now it has a P06 ecu running the d16y7. it idles really messed up. it will jump from 700 RPM- 1300 RPM and sound like its about to die. when i get on the gas pedal, it wont start picking up until around 1500 RPM. it boggs mad crazy when its idling. Just wondering if i gotta do anything with the timing or the if it has to do with any sensors going bad.
Also, the clutch pedal seems to have too much play. It can be pressed down about 1/2 way down before it starts engaging the clutch. I added more brake fluid into the lines and attempted to bleed the system, i havent noticed any leaking, i dont think my slave cylender is going bad. is my clutch just going out?
any help will be appreciated. Thanks, Joe
