Longitudinal 1.8T Eliminator Turbo Kit -
This is bolt in turbo kit, using a genuine Garrett CHRA in a custom KKK exhaust housing. Includes all installation accessories, instructions, etc to be a direct fit power solution for any longitudinal mount 1.8T A4/Passat.
GT2871R Eliminator, which flows enough for 400 crank horsepower.
B6 Intercooler Kit: (+$880.00) Catless Downpipe: (+$150.00) GT2871 Upgrade (400hp): (+$99.00) High Flow Exhaust Manifold: (+$315.00) Silicone Turbo Inlet Hose: (+$325.00)
Stroker Kit, 1.8t to 2008CC-
This kit provides faster spool through increased displacement, will allow for increased boost and timing advance by lowering the compression ratio, and features forged crank, pistons, and rods that are capable of handling 800+ HP.
Achieves a total displacment of 2008CC.
Fits all 06A/06B block 1.8Ts.
What's Included:
New 2.0L FSI crankshaft w/ correct 06A/06B oil pump gear pressed on
Supertech 83MM forged pistons in 9.0:1 compression
Scat 144/20 forged connecting rods
Stasis Track Sport Suspension-
Improve your confidence behind the wheel by flattening body roll, brake dive and acceleration squat. Your car will perform admirably at the track with a civilized ride on the street.
Decreased Body Roll, Improved Steering ResponseCombining strong low-speed damping with digressive high-speed damping gives high performance handling with daily driven ride quality.
Ride Height Adjustable
Easily adjust the ride height to the level that you want. From lowered to the original ride height, there is a wide range of adjustment.
Rebound Damping AdjustableRebound is adjustable allowing you to further adjust the handling and ride quality.
KONI Cadmium Plated Adjustable Dampers
KONI Linear Rate Springs
STaSIS Mounting Hardware
UHMW Spring Perch Bearings
Big Brake Kit, A4 1.8t, 034 AP Racing
- 12.7", 321mm x 30mm solid steel rotor
- Black AP Racing 4-piston calipers (with dust seals)
- DOT approved brake lines
- High-grade mounting hardware
- 034Motorsport Billet Caliper Carriers which feature threaded steel locking threads and black hard anodizing.
- Ferodo DS2500 brake pads which we've found to be an excellent dual use street/track pad. We have run our 300HP 1.8t A4 at several track events with these pads and experienced no fade under extremely hard driving.
Exhaust System, B6 Audi A4 1.8t 3"-
If you're looking for something more than the pedestrian systems offered by most companies, look no further. This system is designed for no compromise performance, enough flow for the 600HP+ big turbo installations, but free flowing enough to show gains on even a stock turbo.
High flow, straight through 3" to dual 2.25" center muffler, running to dual high flow, pass through 2.25" mufflers with 4" slant cut tips. All mufflers, hangers and tubing are 304 stainless steel, v-band flange at front connection.
Done
