Need a couple questions answered
  • Thread starter Thread starter Cykotic
  • Views Views 989
Cykotic
Ok so I blew up my F23a in my accord. Now I need a new motor was thinking of getting an h22a but i have a few questions
Does the h22 drop into the F23 motor mounts?
Does the transmission bolt up also?
How had is it to wire the harness? Does the f23 harnness fit the p13 cpu?
And any problems i may run into?
Any other info i would need would be great also thanks
-Yes, with modification to the driver's side mount.
-Yes, but you'll be infinitely happier with an H22 tranny.
-Not hard. You'll have to lengthen some wires, and add a couple of wires. Otherwise, it's plug-n-play at the ECU.
-Nothing that you won't possibly run into with any other swap.
[post=535514]Quoted post[/post]​
Make sure you get an OBD2 motor if you want to save on hassle.
