Need Big Time Help
  • Thread starter Thread starter pkennedy
  • Replies Replies 1
pkennedy
My son came home with a 92 hatch with a LS Vtec swap. Looking at the engine I notice several parts missing. The engine is a B18B1 with a GSR head and B18C1 intake manifold. The parts missing are the charcoal canister and EVAP purge control valve.IAB tank and IAB bypass valve. Went to a junk yard and picked up all the missing parts. The Ecu in the car is a p06 that was chipped by Phearable.net. I want to wire in the two valves but the p06 ecu doesn't look at intake air bypass but intake manifold need intake air bypass system to operate the butterfly valve in the manifold. My question is now what can I do? The car failed state inspection because these missing parts.
Either get a p72 ecu or send the current ecu out to get a stock gsr tune on it. Even then, I'm not sure sure the P06 will have the capability to even run IAB's even with the chip.
