need some help asap...
  • Thread starter Thread starter podagee
  • Replies Replies 3
  • Views Views 897
podagee
as i said in the other ef place,my b2 took a crap.im swapping motors and here is the pieces i have,d16a6 block,d15b7 block and head,and a crappy d16b6 head.i was thinking of the a6 block with the b7 head?(probably the one ill go with)...or b2 head on b7 block?(doesnt sound too great)someone let me know please.
tranny is off the a6,doing non-v for now until im ready for more wiring.please help me out with what would be best.and please...no answers like go with a z6 head...im only using the parts listed above.
oh yeah how do you know if your ecu is bad?
do a mpfi conversion, and use the a6 block and b7 head and the a6 tranny. if you can pick up an obd0 distributor get it because I think it should bolt right up because if you can get one, then you wouldn't have to convert to obd1
mpfi swap done got everything dizzy done pm6 done everything is ready.thanks what would be the compression ratio?
