other problem need fast replied
  • Thread starter Thread starter D16a6EF
  • Replies Replies 1
  • Views Views 745
D16a6EF
4 CKP - crank position sensor
10 IAT - intake air temperature sensor
15 Ignition output signal
and how can i fix and located them?
i know the 10 IAT is, but 4 and 15 i dont know about 15
4 CKP - crank position sensor - this is located in the distributor. I don't have the pin out on hand so you may need to look this up make sure the wires are correct on your dizzy and also check the tolerances i don't know what the are of hand.
10 IAT - intake air temperature sensor this sensor is on the back of the intake manifold follow the same as above
15 Ignition output signal - I have no idea someone else help me out
you can get a free manual download from Hondahookup.com - Honda / Acura Aftermarket Parts, Accessories, Forums, Photo Galleries, Racing, and more!
you have to sign up though.
