password jdm 3pt strut bar DiY
kakaroto_ss4
goodluck,your better off making the whole setup from scratch with your own specs.just make sure you get everything in place before welding it up..thatd suck to get it all made and it doesnt line up
Creativity and imagination yo!
My friend has one for an EG. I could measure it but first off, you know it uses ovular bars with an internal center support? Idk where to buy that but maybe you do. I say you can go overboard with a welder and a few chunks of steel and 1up that bar. Just do something to prevent corrosion. PasswordJDM uses a real nice powder coat if you've never seen it in person.
pwjdm is the same as that basically.. its jsut square and doesnt have the center support, but neither does teh Carbing bar.. so its not necessary
So you have to drill holes into the firewall to bolt down the center.
if it was designed for the car then it should bolt right in.. but again.. some where designed for RHD cars in Japan, so they're not going to fit exactly the same on a LHD car
