piston to valve clearance question
  • Thread starter Thread starter BigBoy
  • Replies Replies 1
  • Views Views 860
BigBoy
Will swapping out my oem valves for standard size flat bottom valves affect the piston to valve clearance? I want to install some supertech high comp valves in place of my stock ones. I just want to check with u guys instead of claying the motor.
Current setup:
jdm b16a
p30 pistons
1 layer oem gasket
You will be fine. Flat bottom valves just fill in the concavity that oem valves have on their faces. Won't change valve clearance a bit.
