khai_tuan_nguyen
Hi,
My setup is b20b block with b16 head in a 97 civic. The car has JE 12:1 CR pistons and until i get hondata I have timing back at 14 to stop pinging. Well it still pinged so I was recommended to get a fuel pump and fpr upgrade until i get hondata.
So here is the problem. I installed walbro 255 lph fuel pump and modified stock fpr with B & M.
The first problem was that the fuel pressure would not go down under 60 psi and my car bogged during acceleration. I was then told that it probably was because the stock fpr was not regulating fuel and that i should get the aem one.
I recently bought the aem one and installed it, my pressure is now at 40 psi with vacumm connected, however i still can not raise psi or lower it and my car bogs more than before and at idles at certain intervals it bogs and even sometimes turns off the motor. Any ideas???
Thanks
Khai
Thanks
Khai
