please i need help for my engine...
  • Thread starter Thread starter nerdymind
nerdymind
Dear all,
i just bought an engine and i don't know what it came out...
the engine shows this numbers:
B16A
1005338
vtec engine
please if anyone can give me detalis for this engine!!
thnx all
ayman
It could be one of these two, this is right off wikipedia, try searching and you can find a lot
JDM B16A (First Generation)
The first VTEC engine Note: All Honda Motor B16A engines are stamped 'B16A' (with no number after the "A" to identify version).
VTEC
Found in:
1988-1991 JDM Honda Integra RSi/XSi (DA6/DA8)
1989-1990 JDM Honda CRX SiR (EF8)
1989-1990 JDM Honda Civic SiR (EF9)
Displacement: 1,595 cc (97.3 cu in) 1.6 liter
Compression: 10.2:1
Bore: 81.0 mm (3.2 in)
Stroke: 77.4 mm (3.0 in)
Rod Length: 134 mm (5.3 in)
Rod/stroke ratio: 1.745
Power: 160 PS (118 kW; 158 hp) @ 7,600 rpm & 15.5 kg·m (152 N·m; 112 ft·lbf) @ 7,000 rpm
Redline: 8100 rpm
Transmission: S1/J1/YS1 (4.4 final drive), Y1 (4.266 final drive, cable clutch, optional LSD)
ECU code: PR3-003 (DA6/DA8), PW0-000 (EF8/EF9/DA6)
OBD0
JDM B16A (Second Generation)
Found in:
1991-1994 JDM Honda Civic Sir/SiRII (EG6)
1991-1993 JDM Honda Civic Ferio SiR (EG9)
1992-1995 JDM Honda CRX Delsol SiR (EG2)
1995-1998 JDM Honda Civic Sir/SiRII (EK4)
1995-1998 JDM Honda Civic Ferio Si (EK4)
1992-1993 JDM Honda Integra Xsi (DA9)
Compression: 10.4:1
Power: MT: 170 PS (125 kW; 168 hp) @ 7,800 rpm & 16.0 kg·m (157 N·m; 116 ft·lbf) @ 7,300rpm
VTEC engagement: 5600 rpm
Redline: 8200 rpm (AT: 7700 rpm )
Transmission: S4C/Y21/S21 (4.4 final drive, optional LSD)
ECU code: P30 (EG2/EG6)
OBD1
if the word VTEC is bigger than DOHC on ur valve cover then its a second gen b16a...but if DOHC is bigger than VTEC then its first gen... :)
