power consumption
  • Thread starter Thread starter acourt
acourt
when a vehicle is running and an alternator and /or battery cannot keep up with the demands of a car audio systems draw of amperage or whatever, and the amps start to fail/ run out of juice, would amps [that keep the wattage output constant when voltage drops such as JL Audio's] solve this problem or would a system require a high output alternator reguardless of the type of amp used? <_<
[post=493495]Quoted post[/post]​
A 1.0 Farad capacitor should help keep your lights from blinking and stuff, but a higher output alternator should solve the problem the best.
Kinda on the topic, but still kinda stealing the thread... what kind of power do the stock alternators put out and how much would a higher output alt put out?
I'm having the same problems with the lights dimming at idle at times.
