Prelude gauge cluster question (with swap)
  • Thread starter Thread starter Luded
  • Replies Replies 3
Luded
Hi i have a 92 lude s non vtec and it had the red line at 6500ish and the h22a red lines at 7500ish the s stock gauge goes up to 140 and the vtec cluster goes to 200. Do i have to replace my s cluster with a vtec cluster when i swap or can i still use the s cluster and just ignore the red line etc?
Just use the stock cluster, the redline is for the motor, just rev it til the motor's redline (not all the time) just whenever you want to.
Quoted post[/post]]
so none of the sensors will be off? b/c i am going to replace the cluster later with all digital so i dont wanna buy a vtec cluster then buy digital.
yeah youll be fine with the stock cluster. Itll scare you (and your friends) if you rev it up to 7500+, but your engine will be fine. The cluster wont cause any harm.
