Prelude transmission
  • Thread starter Thread starter ovcrash
  • Views Views 679
ovcrash
What other transmission i could use with a 97 H22A, beside the stock one..??
Unless Beson ever got that adapter plate to mate the B-series to the H22 off the ground, you're SOL.
the accord tranny will bolt to an h22 block but its not great gearing
big gap between 2nd and 3rd and 3rd and 4th and 5th won't pull as hard... i would stick with a h22 trans unless you blew that shit up and need a cheap replacement...
oops, didn't even consider the obvious. Figured it was a performance based ?.
Any H or F series tranny will bolt up, minus the S2000 of course. Unless you plan to boost, stick with H22. The H23 is a decent second choice. F series is least desireable unless you boost and want longer gears.
