Q Bout D Series Mix And Match
  • Thread starter Thread starter mini1.6i
  • Replies Replies 3
  • Views Views 679
mini1.6i
just wonderin will the d16a1,a3,a8/9 head can bolt on the d15b7 block or other sohc d seies block...
Well I'm sure you can find someone who has, but not easily or cheaply. Get a Z6 head, flows better than Y8, or an A6 head and a good cam for it. (since you have the B7 you could just get a cam from delta cams and a Y8 IM the A6 valve train is a little better than your B7, but the head is the same otherwise)
so no way i can made it coz someone told me i can redrill i hole @ the dohc d series head and they will fit no problem.....
