Queston about my ls motor and tranny
BEYAKO795
Wanted to know if type r pistons, valves, cams, cam gears would fit in my ls motor and would a stage three clutch for a type r would fit my ls tranny
pistons.. sorta... will fit the bore but the won't fit your rods. Aftermarket rods will work.
cam gears, yes, but pointless... it's the same non adjustable thing as what you have
valves, cams, no
some do, most don't. generally, b16/itr stuff swaps, and ls/gsr stuff swaps. so, probably not.
Pick up the Civic SiR pistons out of the b16.. will raise the compression to a comfortable increase!
Thats what im pushing in my set up... sitting at 11.5:1 compression on 210hp.
LS/Vtec
