Safe rev for a d15b2
A friend of mine has a 90 Civic hatch DX with a d15b2. His car is not equiped with a tach, so we are going to install one. No not a monster tach, just a lil one that get the job done. sorry to disappoint you guys... :P But anyways, i would like to know where the red line starts on these motors. Thank you.
hmm... if i remember correctly ,. the redline on the D15 motors starts shortly after idle...... but realistcally... i wouldn't take it past 5500... maybe 6000.....
well... we are talking about an older motor... i am sure it will rev higher than that... and i am not sure where the fuel cutoff is, probably 65-6700 RPM,
but the numbers i gave are strictly for "playing it safe"
ya i blew my b2 at 8200 rpm and the second one worked up to 7200 with the limiter removed and fuel bumped up. I still have the b2 as a back up in the corner and it ran strong for 7 mounths until i removed it
6500 should be a good redline. My d15 will pull until around there, then it runs out of cam, ha, I need to do a mini-me ;)
