Sensor Under Oil Filter On H22a?
afterburners
Where does the sensor and wire go to that is under the oil filter in the jdm h22a. The wire is yellow/red and it is not in the diagrams?
should definitely be oil press. there should only be 2 sensors on the back of the block. above filter knock and below pressure. pressure has one wire attached with small phillips type 1 screw.
i know this Q is for a H22a but on my old D16a6 it was like this.
if it has one wire, its oil pressure
if its the two wire sensor, its the coolant temp sensor.
if its above the oil filter and one wire and vtec, its knock sensor.
