PLA5151
Okay, so I was driving home last night. In the low rpm's (about 2k thru 4k), throttle partially open, second, third and fourth gears....my car is sputtering, I could noticeably open the throttle and the car was simply just not responding to it, heard lots of misfiring as well. I've had this problem to a much lesser and infrequent extent in the past. This time I actually played with the throttle a little bit when I was driving and got it to throw a code. Got home and jumped the ECU. :disgust1: It threw 7 codes at me....
---- Code 1 (primary O2 sensor) <--- pre-existing
---- Code 6 (ECT sensor)
---- Code 10 (IAT sensor)
---- Code 12 (EGR lift)
---- Code 20 (electrical load detector)
---- Code 21 (VTEC solenoid valve)
---- Code 41 (primary O2 heater circuit malfunction)
Other than the conditions listed above, the car runs fine, ran at WOT out of that RPM range and the car had no difficulty at all. Checked my grounds and they are all clean and secure. Wondering what else you guys think I need to check or suspect?? Thanks in advance
