shift linkage
del sol linkage will work as long as its for the B series DOHC motor, the d series del sol linkage is different and will only work on civics with d series motors
ok then why is it that the ONLY linkage that will work on a del sol with a B series swap is the on from the del sol VTEC????????
cuz its DIFFERENT
you might be able to modify it to work but why fucking bother when you can just get the right one to start with
yeah, gsr and civic Si linkages for a hatch, del sol VTEC for all b series sol swaps
i would have listened to the guy with 5k posts over the guy with 50
thank you.
even the del sol d-series linkage is not the same as civic d-series.
the shifter is in a difeerent position in the car, and the linkage has another bend in it.
del sol vtec linkage = del sol with b-series swap ONLY
No, No, No. Delsol is exclusive to Delsol. As said above you need teg, or civic B series linkage for a civic B swap.
