SiR2 B16 Clutch question...
  • Thread starter Thread starter caddytwix
  • Replies Replies 3
  • Views Views 3K
caddytwix
My clutch is packing it in and I was about to order a clutch, noticed that some clutchs the part number is the same for GSRs and B16s, but some have different part numbers.
I would rather buy the 94-00 GSR clutch instead of the B16A2/A3 clutch because the price difference is about $100. Anyone put a GSR clutch in a b16 before?
Oh ya, and I have a JDM B16 SiR2 motor/tranny with LSD if that make a difference...
Clutch parts for any 92-present b-series trannies should be interchangeable, as they all use the same output shaft. 90-91 cable trannies have a different out put shaft, so that is your only anomaly. How do I know this? I own a 91 integra, and it is hard to find interchangeable parts for that car.
Quoted post[/post]]
Yeah, the only difference i could see being is the output shaft size and the flywheel, but if the output shaft is the same, i would assume it should fit.
Thanx for the info
