SIR2 B16A2 o2 sensor question
  • Thread starter Thread starter 93SIR2
  • Replies Replies 5
  • Views Views 3K
93SIR2
I have a SIRII B16A2 OBDI motor. Which oxygen sensor do I use?
you have an obdI b16a SiR II, not a b16a2.
What car is it going into? If it's going into an OBDII chassis use the O2 before the cat.
[post=513741]Quoted post[/post]​
93 Del Sol Si. Its been in, its just setting off o2 sensor codes now. I was just told I could use any 4 wire sensor from 92-95. Just seeing if thats true.
You can use pretty much ANY four wire o2.
yep, your stock one or the one that came with the motor will both work.
if you're throwing a code for it, the sensor it self is probably shot, or not plugged in. requires 0 wiring changes from what you had to the new motor
