Skunk2 Stage 2 - basic setup tips?
  • Thread starter Thread starter BallyVTI
  • Replies Replies 22
  • Views Views 3K
Originally posted by pissedoffsol@Jun 19 2005, 11:29 PM
sell the emanage and get a chipping setup and run uberdata or crome software on it. thats the only real way to tune a car. the piggy back systems just don't work that good.
[post=514018]Quoted post[/post]​
Thinking about it... new ECU already acquired :)
B.
Guys,
What would happen if for eg. the cams were not installed with the correct centerline?
B.
not sure what you mean by center line....
the gear only goes on one way- theres a tooth notch for the pin.
as long as the gear is up with the crank puley (crank has the same tooth feature) you can't get them 180 degrees off. its impossible.
