formby
learning in progress
i want more power from my stock [81.5mm] block lsv somewhere in the 200-250whp range; and i want to spend under 500 bucks.
i'm done with drag but ill be going to autox events in the near future.
so i was thinking that if i got a small turbo and a simple set up i could have no lag and just enough turbo to get me to the 7.3k red line i use.
when i mentioned my plan to Anthony he told me he had a turbo from a 90ish 300zx i can have free.
[Garrett TB22/TB02 with integral wastegate, 9.8 psi max boost]
the turbo is a t25 i think and i dont know much more about the turbo.
1. i want to keep my AC, but i dont know who could make me a manifold with a flange to fit the turbo.
2. i think the WG on the turbo will hit the block.
3. i'm pretty sure this turbo will run out of steam at a low rpm. but i have no idea where
i have an extra block and eagle rods that i want to build with stock sleeves and 10:1 cr for a future FI build. i also have 450 dsm tuner toyz injectors, and the the box to run them. ohh and the p28.
what should i do?
would the turbo make power?
what happens when a turbo is maxed out at low rpms?
what should i do?
