Luis998
Honda Enthusiast
that's probably be cause there is a problem in the installation of the chip, take out J1 jumper so the ecu doesn't use the chip and it should work like a virgin one !
That was one of the first things we tried.
 First we tried running the ECU with the chip, then without, then with a new one with the same base map burned on it and no dice. Hopefully my car will be ready tomorrow and I will give an update as to what the problem was...at least with mine.
