sr20det spark plugs
  • Thread starter Thread starter VTECPOWER
  • Replies Replies 7
  • Views Views 8K
VTECPOWER
For my sr20det i know to get sentra ser (sr20de) spark plugs, but since the det is turbo, i was wondering if anyone knew if i should get a different kind of plug ie: hot or cold, or any suggestions for that matter.
Thanks
From Zilvia
Originally posted by oumu
The correct OEM plugs are double platinum:
NGK PFR6B-9
And I think this is the Nissan Part Number:
22401-27N66
You can also use NGK Iridium:
BKR6EIX
BKR6EVX
BKR6EIX-P
Or traditional spark plugs like he listed:
BKR6E
You can change all those sixs to sevens to get colder plugs.
(e.g. BKR7EIX)
Hope it helps
NGK Iridium:
BKR6EIX
BKR6EVX
BKR6EIX-P
read on the specifics of each of these plugs, find out how they suit what you do, then choose the right one.
^ i should know this, but i dont. . . . which ones are for the SR20DET in stock form?
Um, i know the stock heat range is 6, but you want a colder plug with more boost. And I know down the road comes a new tune w/more boost.
