Swap Engine NEED help!! plz...
  • Thread starter Thread starter alexsandra
  • Replies Replies 5
alexsandra
I have a 1993 Honda Civic Coupe it had a D16Z6 & it got swap into a D15B7 :( and the problem is that it wont start!
I all ready connected everything, new Distribuator, timing belt, Spark plugs/wiers, new Gaskets.
The only problem is that all it those is CRANK but NOT start. :mad:
what other basics should i be looking at? What more can i do?
ANY HELP:confused:
aka newbbie at this shit ^_^
Grounds. One on the transmission to car. One on intake manifold to car. I also have one more near the crank. And your engine harness has a ground to the motor (using all the other grounds you connected to the chassis) right at the thermostat.
If that ain't it.....you need to check for fuel and spark
Thankyou! im going to check that out
and the Fuel and the sparks are good
so im going to try the other options!
ill keep informed IF it turns on lol :)
Cars need 3 things to run, fuel, air and spark... Also a car will not run if the valves are so far out of wak it fails to start, just another idea
