Originally posted by superstreetb16@Feb 16 2004, 12:42 PM my t.p.s. sensor was broken when i got my b16....can i use any honda tps sensor or i need a b16 sensor???
Get any honda tps, except the one from a 88-91 dpfi dx. However, the dpfi tps will also work but you have to take the trouble to swap the two outer wires around. All the honda tps have the same programmed voltage settings. Approx 0.5v at idle and 4.5v at WOT. The voltage changes relate to the relevant ecu you are using to adjust the injector pulse width.
